New Build Solutions, read and chime in...
HERES MY NEW BUILD SHEET AFTER SPEAKING WITH MARTIN@TICK ABOUT A CAM.
LQ4 STOCK, 13K MILES. CLEAN!! CROSSHATCH BRAND NEW!
LS6 MANIFOLD, INJ'S, RAILS
P&P DRIVE BY CABLE T.B.
853 HEADS, PORTED IN,P&P EX, SHOULD FLOW 270/210 @ .600
SNS TORQUEMAX STAGE3 235/239 .62X/.62X LSA 112 +2
LUNATI ROLLER LIFTERS
1 7/8" HOOKER 240SX SWAP LONGTUBE HEADERS
THIS IS GOING TO BE A BEASTLY IRON LS2
BUT I AM TRYING TO BUY SPRINGS ON A BUDGET THAT WILL WORK WELL WITH MY CAM AND NOT REQUIRE POCKET MACHINING. PLEASE CHIME IN GUYS. THIS IS MY FIRST GEN III BUILD. THANKS
Looks like your building a nasty s14.... Good luck as well, but luck is not needed, just money.... Lol
The duals are well well worth the extra weight. They also give you some peace of mind that if one spring breaks you still have a chance to save your motor. If that beehive snaps, and lemme tell ya how many times people have had that happen! You are gonna lose a cylinder.
And the ls6 casting are way better, tbey would be worth probably 20-30 hp more
the duals are well well worth the extra weight. They also give you some peace of mind that if one spring breaks you still have a chance to save your motor. If that beehive snaps, and lemme tell ya how many times people have had that happen! You are gonna lose a cylinder.
I mean seriously, if i mill these 853 and port the snot out of em theyre still bad?? That makes no sense.... If i mill them say .020 will i have ls6 intake mani fitment issues? If not im just gonna mill them.
They wont be as good, not much different maybe 20hp or so, but they are worth it.
I sold my 243 heads locally for $350
And you can mill them more than that if you have the ptv clearance. I wouldnt mill past .030 though. I like to leave room to resurface in the future should something happen.
