Why so few 366 strokers???
Old Apr 20, 2004 | 10:29 AM
DenzSS's Avatar
Anything over 4.00" stroke starts to get into some really bad piston geometry.
Old Apr 20, 2004 | 12:17 PM
VortechC5's Avatar
Do you know what the story is behind the 3.77" cranks. I bought a shortblock based on one and am curious. I was told that it was a Lunati forged crank that was ordered by GM and then never used.
I believe that GM custom ordered some 3.77 cranks for some projects and I knew of one that was available, never used for about $1100 PM me if interested.
Old Apr 20, 2004 | 01:33 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I believe they were of Lunati manufacture. I only found one running car with this custom stroker and I am not clear on the story, but they did order a bunch of 3.778 forged cranks for special projects.
Old Apr 20, 2004 | 03:22 PM
30th TA 0219's Avatar
what problems have you heard about offset cranks? TSP put down INSANE numbers NA and especially on the juice with that "weak" crank.
This has been brought up numerous times...show me someone who ahs broken a crank.
FYI stock cranks go for $200-250 ALL day on here and eBay, and when your are all done with an Eagle crank it's a lot more than $1000, and will anyone ever trust them afetr the initial fiasco?
Old Apr 20, 2004 | 03:27 PM
DenzSS's Avatar
There is always the $1200 Callies Racemaster. Good crank.
The stock crank is fine. I just don't see the point in spending time and energy into an offset ground stock crank when you aren't very far from a $1200 Callies. You're talking about $800. Most guys spend that on far more foolish things than a good crankshaft.
Old Apr 21, 2004 | 08:00 AM
VortechC5's Avatar
Thanks for clarifying exactly what the stroke is. Speed Inc. put the shortblock together for me and I couldn't get them to measure exactly what the stroke is. I should have it soon. I am just waiting for them to ship it.
Old Apr 21, 2004 | 09:42 AM
DenzSS's Avatar
Huh??? Sorry, just seems silly to me. I would never let anyone assemble an engine that could not/would not tell me the stroke.
Old Apr 21, 2004 | 04:05 PM
PREDATOR-Z's Avatar
Fully agree. that is
Old Apr 21, 2004 | 05:05 PM
VortechC5's Avatar
I had alrady paid for everything. I bought it from another forum member and the parts were already at Speed Inc. I asked Speed Inc (on 4 separate occasions) to measure the stroke for me so that I could verify that it was the 3.77" that the seller told me.
Old Apr 22, 2004 | 02:51 AM
PREDATOR-Z's Avatar
Let us know how it performs when it is done. This is somewhat of unchartered teritory and I'm curious as to how these offset strokers fare Vs the others.
Old Apr 22, 2004 | 10:29 PM
Eric111's Avatar
Can stock rods and pistons be used when offset grinding the crank, or do you have to change rod length?
Old Apr 23, 2004 | 01:30 PM
  #32
lsx24's Avatar
Good question; I want to know if the change is recommended also or is it just crank.
Old Apr 23, 2004 | 01:31 PM
  #33
DenzSS's Avatar
Piston needs to be changed, you should increase the rod length if you can.
Old Apr 23, 2004 | 05:59 PM
  #34
ktmrider's Avatar
There was another shop offset cutting cranks, goes by "Hank the Crank". Good article in the Chevy Hi Performance rag last month I think. Article goes under "LS1 bottom end for less" or something along this line.
The 366 they ended up with had a CR of 13:1 and put down some amazing numbers. No mention of potential issues but hey, at least there are some options.
Old Apr 23, 2004 | 09:29 PM
  #35
HTC is anything but affordable. The magazines suck his "crank" so much is frightening.
Old Apr 23, 2004 | 09:55 PM
  #36
427 LS1's Avatar
Guys I have an unassembled shortblock, using some real nice pieces. It is a stock crank that has been offset ground to a 3.776" stroke and has been ion nitrided and also cryo treated, that is about as strong as you can make the stock crank. Also, I have a beautiful set of like new lightweight Carrillo H-beam rods and brand new lightweight Lunati forged pistons (-11cc dish) with bearing and rings, it's ready to put together if anyone is interested, that thing should turn some serious RPM with the lightweight rotating assembly and high quality parts. I have a LS1 block that has been honed for the pistons and ready to go. It's a 362 cube setup. I need $2,500 for everything and I can be reached at indacalinc@sbcglobal.net Thanks Dave
Old Jan 12, 2008 | 01:56 PM
  #37
trc725's Avatar
also a 366 is a bigblock gas for trucks have a 98 for sale
Old Jan 12, 2008 | 05:35 PM
  #38
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Since this thread has been brought back from the dead I'd like to asks a few quesions. Anyone have some long term durability tests yet? I notice this has been close to 3.75 years now. You'd have to change pistons. I don't know of anyone that makes a set up for a 3.77 stroke in a LS1. Were forged cranks really so expensive for LS1s back in the day?
Old Jan 12, 2008 | 06:23 PM
  #39
99mongooSS's Avatar
**** callies makes strokes all the way to 4.250 for lsx engines.
Old Jan 12, 2008 | 09:36 PM
  #40
LSXS10's Avatar
If i use a 6.0 iron block and an offset ground crank what rods and pistons?? What is the rod jornal diam. how much do they cut? Honda rods??? custom pistons?? Sombody let me know some info....
