ms4 specs help
Alrighty i just bought a ms4 cam from a member on here it was brand new and i got to looking on the the cam box and the specs were. .651 intake. .608 exhaust on a 111.5 lsa it says right on the box ls1-ms4. i just dont understand why the specs are different than a normal ms4. And also will i still be able to run this cam in my car stock bottom end ls1 with stage 1 prc heads with patriot gold. 650 springs. Just very leary on the specs. Hopefully someone can help me.
The TSP EHT .675 springs are extremely stout for a stock pocket spring, you won't have any issues as they are almost 500 pounds open at your lift.
Stop giving advice before you give somebody even less clueless then you are bad information. The lift a spring is rated to has absolutely zero to do with how weak or strong a spring is.
