Forged 6.0 iron block buildup
Old 04-18-2004, 04:09 PM
Default Forged 6.0 iron block buildup
I am going to build a forged iron block for my Procharger setup. Would you guys mill the heads, bore the block?
Would you leave all of that alone to have the compression ratio low and turn up ther boost.
I should be able to get the heads to flow more without milling them to raise the compression ratio. I was looking at getting the 6.0 heads with the 317 castings.
What do you guys think?
I want
6L LS1 Cast iron block (honing cyls, blueprinting, balancing)
Pistons (Dished for Boost, 4.030 bore, 3.622 stroker.)
Connecting rods
rod bearings
Main bearings
Comp-R Lifters
Comp 918 Valve springs
6L Truck heads
6L GM crankshaft
Thanks
Old 04-18-2004, 07:08 PM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
Looks good. Should be a pretty good combo when completed. If you need any help a long the way, feel free to give us a call.
Thanks
Old 04-18-2004, 08:13 PM
T/A Medic's Avatar
u dont need comp R lifter with 918 valve springs... and if u go with comp Rs a lot of people have not had good results without adj rocker arms... though some people do get away without an adj rocker arm
Comp Cam says Comp R "REQUIRE" Adj Rocker Arms...
u dont want a higher compression ratio you will have to run less boost...
10+:1 probably be able to do 6psi ... u will get more HP from less CR and more boost than More CR and less boost...
And call APE if u get stumped they are muy knowledgable... and they will be able to point u in the right direction, depending on ur HP Application
FYI...
Old 04-18-2004, 11:37 PM
NA$TY-TA's Avatar
That .030 over bore 6.0L block is exactly what i did....... I had AP Engineering build my short block and i went with 6.0L heads and 6.0L MLS head gaskets for my procharger setup...... heres some pics of mine with coated pistons.
370ci Iron block
Diamond 4.03 -15cc dish pistons
Coated piston up close
Short block and tranny almost ready to go in.
Heres the run down on the Shortblock
9:1 Compression Forged 370ci Iron Block Built by AP Engineering
Polished & Magnafluxed Stock Crank
Diamond Forged Ceramic Coated -15cc Dish 4.03" Pistons
Diamond 4130 Chromemoly Wrist Pins
Diamond Pro Select Ring Set/ File Fit
Eagle H-Beam Connecting Rods 6.125"
L19 ARP Rod Bolts
Federal Mogul 152M Main Bearings
Clevite CB663H Connecting Rod Bearings
ARP Main Studs
Blueprinted & Fully Balanced
Pinned crank
Comp XER 230/236 .592/.602 on a 114 LSA + 4
Ported LS6 Oil pump
Jwiss timing chain and Gears
And some other stuff i might of forgot...
Kyle
Old 04-19-2004, 03:21 PM
Okay I see your point I will go with comp stock replacement lifters.
I se your list of mods
http://www.itlxlr8.homestead.com/mods.html
L19 ARP Rod Bolts
ARP Main Studs
ARP Head Studs
Thunder Racing Chromoly Pushrods
Patriot Performance 317 Casting 6.0L Stage II Heads
71cc Chambers
These are some of the mods I want to use or round about.
