AI LS6 heads vs TEA STAGE 2 LS6 heads vs TFS 215s
I did a build with tea stage 2's 60cc chambers very lite fly cuts eps cam fast 102 stock water pump kooks 1and7/8 header's hand made y flowmaster merge 4 inch cut out. and pump gas 93 around here made 496 and 430 tq nothing crazy. stock rockers with bearing up grade ls3 valves very cheap upgrade for the power and help valve spring life. this is a street car as well and driven. the tea stage 2 is a bad *** 243. very under rated.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I got this...
http://www.totalengineairflow.com/pr...s2ls6-stage-2/
Their stage 1 keeps the stock valves...
http://www.totalengineairflow.com/pr...s2ls6-stage-1/
Those are included. These are also the same valves they use when they work the TFS 215s ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I got this...
I got this...
According to this they are 226cc and thats what I thought they were but it may have changed. Best thing would prob be to ask Mike@tea.
http://www.hotrod.com/techarticles/e...t/viewall.html
