studs or torque to yield?
Old Feb 12, 2013 | 06:04 PM
farmington's Avatar
Default studs or torque to yield?
Changing heads and trying to decide if I should use studs or factory TTY bolts. Can the heads be installed and removed with the studs in place? replacing lifters with LS-7 lifters and LS2 lifter retainers and using factory head gaskets.
Old Feb 12, 2013 | 06:23 PM
WS.SIX's Avatar
If you ever plan on taking the heads off again go studs. Don't have to worry about spending 4 hours cleaning 30 bolt holes.
Old Feb 13, 2013 | 10:24 AM
01ssreda4's Avatar
Studs, and yes the heads can be removed with the studs in-place just have to be careful.
