How much to mill 243's with MS3?
I've read till my eyes crossed and haven't found a solid answer. My questions is how much can I mill the 243's if I'm running the MS3 on my stock LM7? I know the PTV will need to be checked when it goes together, but trying to see if there is anyone running this combo, or someone that give me more info. Thanks!!
If you don't mind cutting....slap that cam in, measure and cut away. You MAY even have to flycut with no milling as well.
FYI...Nobody here can tell you for sure if it will clear on your set-up
5.3 with the dish. Like I said, I know I will have to check, but trying to seeing if anyone has run a similar combo, and if so, how much they milled. Thanks.
A) Mill the 243's and flycut the pistons to work with the MS3
B) Mill the 243's and find a different cam that will work without flycutting the pistons
C) Different heads
D) Unmilled 243's (which I believe would hurt me because of compression loss)
Like I said, several simple 5.3's on here running really good, so I'm following a lot of their setups. Just haven't really seen any of them running 243's. Any ideas, thoughts, suggestions, or comments would be great. I'm still learning as I go. So let me know my best route on a 5.3, with carb, Vic Jr, and some spray.
B) Mill the 243's and find a different cam that will work without flycutting the pistons.
Thre are plenty of Smaller cams out there that perform great with the higher compression.
