asa cam with more lift
Old 02-23-2013 | 04:53 PM
GreenFormula13's Avatar
Default asa cam with more lift
how would the asa cam perform if you cut it on different lobes like the xer or lsk to get higher lift numbers and kept the same 226/236 on a 110 lsa
Old 02-23-2013 | 05:37 PM
JakeFusion's Avatar
Super Hulk Smash
It would make more power. I'd do EPS/LXL lobes and it'd still make power and be easy on the valvetrain.
s346k's Avatar
most likely almost identical to the Asa cam with slightly more power
Old 02-23-2013 | 10:02 PM
99Bluz28's Avatar
Tick Performance has a cam right up your alley!
Go for the mild version.
http://www.tickperformance.com/tick-...1-ls6-engines/
Old 02-24-2013 | 12:06 AM
thanks for the link 99bluz28 that actually is the type of specs im looking for
Old 02-25-2013 | 12:51 AM
Always2Slow's Avatar
Those two cams are awesome cams to choose from can't go wrong with either one.
Quick Reply: asa cam with more lift
