Mystery O-ring! Help!
Old Feb 24, 2013 | 10:21 AM
Jvmun's Avatar
Default Mystery O-ring! Help!
Long story short I messed up and tapped the crank plug while removing the pilot bearing out of my ls1. I dropped the pan and retrieved the plug. While I was cleaning my pan I found this o-ring sunk at the bottom.
Any ideas? From the oil pump maybe?
Attached Thumbnails Mystery O-ring! Help!-img_0928.jpg   Mystery O-ring! Help!-img_0950.jpg
Old Feb 24, 2013 | 10:32 AM
KCS's Avatar
KCS
Moderator
Yeah, looks like oil pump if that is the rear plug for the crankshaft.
Old Feb 24, 2013 | 10:50 AM
Jvmun's Avatar
I wonder how long its been down in there. Never noticed any problems other than a leak from the valve covers.
How would I get it bank on there?
Old Feb 24, 2013 | 11:01 AM
01_SuperSlow's Avatar
Yup, that's an oil pump o-ring.
I bet the previous owner dropped the ring in the pan and just used another one instead of fishing it out.
It doesn't just come off of the pick-up tube.
Old Feb 24, 2013 | 11:29 AM
Jvmun's Avatar
^ Right?
If the o-ring had been missing from the pick up to for a minute I woud have had other problems right?
Old Feb 24, 2013 | 11:32 AM
badazz81z28's Avatar
Originally Posted by Jvmun
^ Right?
If that O-ring was missing you would have very low to no oil pressure. Like mentioned, the way it's installed on the pick-up, impossible to come off let alone in one piece. Are you the original owner?
I also feel the pick-up O-ring is bigger than the diameter of the pilot hole and a darker blue....Is there suppose to be an O-ring in that general area?
What is the diameter of the O-ring you have there?
Old Feb 24, 2013 | 11:47 AM
studderin's Avatar
ya thats a pick tube O ring, looks new like its never been in the pump, so he droped it and just left it in there
Old Feb 24, 2013 | 11:54 AM
Jvmun's Avatar
I cant think of anywhere else this o-ring would go to. Dipstick o-ring is puny. The original owner claimed he had the oil pump swapped.
Old Feb 24, 2013 | 03:57 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Bingo. Oil Pump O-ring. You obviously have good oil pressure, so as someone already stated, they dropped it in there and never bothered to fish it out.
Old Feb 24, 2013 | 04:41 PM
studderin's Avatar
Old Feb 24, 2013 | 07:41 PM
Jvmun's Avatar
I know this is off topic now, but any ideas on how to install a new crank plug?
Old Feb 24, 2013 | 10:30 PM
studderin's Avatar
3/8 extension, hammer, some rtv
Old Feb 25, 2013 | 11:51 AM
Jvmun's Avatar
How far to i tap it in there?
