stock 243 heads with big cam?
Old Mar 5, 2013 | 08:42 PM
buddhaz06's Avatar
Default stock 243 heads with big cam?
How well will stock 243's do with a big cam? .630/.620 range. I'm on a budget so cnc port is out of the question. Will they really choke my 346 much? I can get them cleaned up and polished for $300. Is it worth it or should i stay as cam only and leave them alone?
Old Mar 5, 2013 | 08:48 PM
z28241's Avatar
The 243's wont choke the motor with that cam, i know guys running stock heads w/cam specs like that. Your case the cam, along w/untouched 243's, will see some some gains, and it will support the cam along with raising your compression ratio. Just make sure u accompany the heads w/ the right springs etc.
Edit: I think $300 is too much for just a clean up. U should be able to get them cleaned up and atleast a valve job for that.
Old Mar 5, 2013 | 09:41 PM
yonerhottlt1's Avatar
Just make sure you have enough PTV clearance. You'll be way better off than the stock heads.
Old Mar 5, 2013 | 10:12 PM
buddhaz06's Avatar
Springs are good and ptv is okay.
Old Mar 5, 2013 | 10:23 PM
Cajun ELESS-ONE's Avatar
what kinda intake/exhaust are you running? ls6 would be good but with a cam like that a fast would do better. guessing u upgraded ur rockers and push rods as well
Old Mar 5, 2013 | 10:32 PM
buddhaz06's Avatar
Rockers have trunion upgrade. Tsp pushrods. Long tubeheaders. Got rid of fast90 for vic jr setup.
Old Mar 5, 2013 | 11:10 PM
deez01ls1's Avatar
Im actually installing my stock 243's with a valve job,dualsprings,etc,upgraded pushrods with the torquer v3 cam. Im doing the install next weekend...will let you know the results
Old Mar 5, 2013 | 11:22 PM
buddhaz06's Avatar
Awesome let me know! I had a pretty mild cam with stock heads a long time ago and it ran great! Hoping it'll run even better now
Old Mar 6, 2013 | 04:25 AM
PREDATOR-Z's Avatar
Hi to all, please when giving cam specs, why do people always think a cam is big if it has big lifts. Cam is measured by durations.
And lift has almost nothing to do with piston to valve clearance. NOTHING.
Old Mar 6, 2013 | 12:08 PM
buddhaz06's Avatar
I was just referring to big compared to stock and head flow limits.
Old Mar 6, 2013 | 12:13 PM
Slowhawk's Avatar
LS1Tech Sponsor
You have to give full cam specs to give anyone an idea how the heads will work.
Old Mar 6, 2013 | 02:51 PM
slamminjim's Avatar
I'm running a 110 LSA cam. Is it big?
Old Mar 6, 2013 | 02:57 PM
creiss21's Avatar
I am running 799 (virtually same as 243) heads and a Trex cam, no PTV clearance issues.
Old Mar 6, 2013 | 03:13 PM
buddhaz06's Avatar
I'm not worried about ptv. I'm only worried about choking the motor.
Old Mar 6, 2013 | 11:41 PM
Detoxx03's Avatar
Posting the specs would help.
Old Mar 7, 2013 | 12:46 AM
xDIRTYx's Avatar
fwiw i had untouched 243's with an ls6 intake, and bolt ons. 240/244 .603 .609 111lsa made 400rw thru a 4k converter 4l60 and 3.73 10 bolt at the time.
Old Mar 7, 2013 | 01:02 AM
autogeek23's Avatar
I'm running untouched 243's with a 236/242 615/615 cam. Ls6 intake, lt's. Through a 6spd made 423/385 on a mustang dyno. HP kept climbing
Old Mar 7, 2013 | 01:05 AM
autogeek23's Avatar
I didn't check ptv. Has been fine for the 4k miles it ran after install. Spun a bearing. Heads are coming off soon so I'll see if there are any marks on my pistons
Old Mar 7, 2013 | 06:25 AM
mark21742's Avatar
Running a 238/242 .595/.595 112lsa cam in my old 346 and had good ptv when measured, but when I tore the heads off to port them I had marks on every piston where the valves touched atleast once....I guess a few over revs? I got lucky and didn't do any damage, but flycut a hair just to be on the safe side.
Old Mar 7, 2013 | 01:04 PM
NoSloZ_1's Avatar
i have been debating on running my 244/244 .613/.613 cam with my stock 863 heads on my truck. or possibly 243/799's but have held back bc i have heard about ptv issues. is it different for every engine?? how come some have issues and others dont? headgasket thickness? CC's?
