Insights on "Lunati 395 Stroker"
Old Apr 22, 2004 | 05:55 AM
DG Gordon's Avatar
I hope these are good mototrs just got back with mine today.
Put down 483.4 and 466.3 tq
Old Apr 22, 2004 | 02:17 PM
kumar75150's Avatar
Damn those are good numbers. What heads/cam are you running?
Old Apr 23, 2004 | 05:16 PM
kumar75150's Avatar
well i typed out a freakin essay and their response was
"no problem" upto a 200 shot
Old Apr 24, 2004 | 03:32 PM
DG Gordon's Avatar
kumar we used the pp stage 2s with bigger valves and hand porting. The dynos were done with less than 100 miles on it It has about 250 miles on it now and it feels stronger now than before.
The cam is one of Texas Speeds big Magic stick cams in the 240 ish range not really that big.
Old Apr 24, 2004 | 10:39 PM
kumar75150's Avatar
very nice
Does it have a 90mm setup? just curious because I am about to get one.
Mine made exactly 484 rwhp and I am going with bigger valves and the 90mm setup hoping to hit 500 NA.
Old Apr 24, 2004 | 10:47 PM
DG Gordon's Avatar
Ported stock throttlebody and stock intake. It does have the electric waterpump for what its worth. I may puta 78mm intake on it later to see if i can get it a little closer to 500, hopping with a few miles on it the hp will come up Texas Speeds dyno is about 5-8 rwhp lower than ours here in Odessa.
Old Apr 24, 2004 | 11:31 PM
kumar75150's Avatar
dont buy a 78 whatever u do
if you are going to spend the money, get the 90mm setup
