Gasket sets
Old Mar 12, 2013 | 12:11 AM
Z28MJ's Avatar
Default Gasket sets
So I was looking for gasket set tonight, and I found this,
http://www.texas-speed.com/p-3621-co...asket-kit.aspx
http://www.texas-speed.com/p-3622-co...asket-kit.aspx
and
http://www.summitracing.com/parts/sl...ubmodel/z28-ss
I can get a complete set from TSP for $500 or a complete set from summit for $250... am I missing something?
Old Mar 12, 2013 | 12:42 AM
Burken01's Avatar
those TSP kits you mentioned are using "cometic" brand gaskets... they are usually 2x the price of stock GM gaskets..
Supposedly the cometics seal better, I know alot of people use them for head gaskets because the come in .040 size to make quench in a ls1 optimal (.030-.040)
I dont know what brand gasket the summit racing uses..
just curious but what do you need a whole kit for, full engine rebuild?
Old Mar 12, 2013 | 12:49 AM
Z28MJ's Avatar
ok thanks.
Well I have the engine out for a cam and head install, plus I had a rear main seal leek. So I figured I might as well replace all the gaskets well I am there.
Old Mar 12, 2013 | 12:54 AM
Burken01's Avatar
yeah, what about this one
http://www.texas-speed.com/p-173-bas...asket-kit.aspx
or this one, should save you some money over the cometic kit
http://www.texas-speed.com/p-194-del...asket-kit.aspx
plus these use GM gaskets
Old Mar 12, 2013 | 11:54 AM
Z28MJ's Avatar
That deluxe one looks like it would have almost everything I need; would still have to get the oil pan gasket and rear main seal, but that still only makes it cost around $400 for quality gaskets plus it comes with the head bolts. I would much rather have quality over cheap
Old Mar 12, 2013 | 12:42 PM
Burken01's Avatar
Yeah can't go wrong with GM gaskets..
