lq4/lq9 stock gm long block
Old 03-17-2013, 05:58 AM
oldmano2z's Avatar
Default lq4/lq9 stock gm long block
got my junkyard lq4 came out of a y2k 2500 series truck. need to know which direction on marking the main caps for disassembly. do i start at the front of the block with the number one, or start at the back with number one?? thanks the oldman.....
Old 03-17-2013, 07:56 AM
sreve's Avatar
Start at the front
Old 03-17-2013, 09:19 AM
96capricemgr's Avatar
doesn't matter as long as you put them back the way you took them off
Old 03-17-2013, 02:35 PM
oldmano2z's Avatar
i thought it was from front to aid the machinist
Old 03-17-2013, 04:10 PM
why are you taking it apart and taking it to a machinist?
Old 03-17-2013, 11:37 PM
1FastBrick's Avatar
1 starts at the front of the block and they are cast into the caps. 1-4 face the rear of the block and 5 faces the front of the block.
Search Google images and you will see or look at the orientation when you pull the pan.
Quick Reply: lq4/lq9 stock gm long block
