crank shafts
Old Mar 17, 2013 | 06:09 AM
oldmano2z's Avatar
Default crank shafts
where do i get the prices for cranks? looking at that lunati non twist for my lq4 build . no stroke just a ten thousands overbore. want to keep the motor somwhat bulletproof and still keep my extra bores on the block and the goal of possibly five to fivefifty horse. gonna be an autocross/ roadhunter motor but mostly a highway star. drive the wheels off,put some more on and drive em off again. gots 6spd and s60/3.54's .any ideas for me. you guys are the pro's out here suggestions are welcome. thanks, the oldman......
Old Mar 17, 2013 | 06:43 AM
Gray86hatch's Avatar
The crank is not a issue till over 1000hp
Tim
Old Mar 17, 2013 | 02:48 PM
oldmano2z's Avatar
so a stock crank should be fine for my app. so just forge the pistons. truck cranks are longer on trans side i have an ls1 crank available will that work?? i think so?? gotta look at it to see if it accepts a 6spd the truck crank doesn,t if the ls1 crank doesn,t have 6spd provisions then a stock GM 24 tooth gun drilled for 6 spd would be good enough for say 600 to 650 hp with arp main cap studs???
Old Mar 17, 2013 | 05:45 PM
bww3588's Avatar
Only the early truck cranks were longer. Any 216 casting crank will work. But everything will have to be balanced.
Old Mar 17, 2013 | 06:19 PM
oldmano2z's Avatar
bww3588, where is the #216 at? i also looked at my ls1 and found a pressed in plug at the back of the crank drilled a hole in it and pulled it out and low and behold i can see the crankshaft dumb move on my part. gotta get a plug now and replace it. does anyone know the depth off hand to see if this ls1 crank will work on a 6spd? and how many miles on a crank would you guys recomend to keep useing? the ls1 has 70k on it. thanks ahead for all your help.
Old Mar 17, 2013 | 06:23 PM
onefast84's Avatar
So 1000 horse on a stock crank? Should anything be done to it?
Old Mar 17, 2013 | 06:52 PM
96capricemgr's Avatar
balance to the rotating assembly.
