pushrod/mill question
Old Mar 18, 2013 | 02:40 PM
dubrado's Avatar
Default pushrod/mill question
got my head back from porter and he said that the back of the rocker arm will be 0.050" closer to the cam centerline, does that mean I'll need a 0.050" shorter pushrod. The head was also flat milled 0.005" for flatness
This is a theoretical question, I'm just curious.
In the long run, I will get a pushrod checker to verify but just want to know.
thanks in advance
Old Mar 19, 2013 | 04:04 AM
vettenuts's Avatar
Why will it be that much closer, did he recess the valves or are they different valves?
Based on his description, yes a 0.050" shorter pushrod should work unless you are doing a cam at the same time. However, if he did do something with the valve height, you need to verify rocker geometry before figuring out the pushrod length. If the heads are off, you can do this on the work bench where it is easier.
Old Mar 19, 2013 | 11:36 AM
dubrado's Avatar
same valves but a valve job was done, not sure how much that changes the valve position.
Old Mar 19, 2013 | 05:12 PM
vettenuts's Avatar
Sounds like they are a little deeper from the valve job.
Old Mar 19, 2013 | 08:30 PM
ckpitt55's Avatar
the answer is on your bench, not the internet unfortunately. you need to measure, OP.
