ls1 build question
Old Mar 21, 2013 | 02:17 PM
zrmurcer's Avatar
Default ls1 build question
I am building an ls1 with forged pistons and I just ran across a set of Eagle H beam rods that are 6.125 long.....can I run these with a stock crank if I order for pistons 4 a 6.125 rod....
Old Mar 21, 2013 | 02:50 PM
Burken01's Avatar
Yes you can run a 6.125 rod with proper piston..
Just make sure you balance your rotating assembly
Old Mar 21, 2013 | 02:51 PM
Burken01's Avatar
And yes forgot to say stock crank will work perfect with those
Old Mar 21, 2013 | 08:14 PM
zrmurcer's Avatar
Thanks for the info.....the eagle rod part # is crs-6125-bs and the piston is a mahl piston part # LS1314905f04......will these work with a stock crank ....thanks
Old Mar 21, 2013 | 08:27 PM
Burken01's Avatar
correct, heres a link with the arp 2000 rod bolts
http://www.texas-speed.com/p-441-eag...000-bolts.aspx
and heres those pistons you chose
http://www.texas-speed.com/p-1104-ma...22-stroke.aspx
they will both work with stock crank.. But just know that piston ^ is made of 4032 material not 2618..
alot of the professionals recommend 2618 since its a softer material and more forgiving when you add a power adder (nitrous, turbo, etc)
Old Mar 21, 2013 | 08:43 PM
zrmurcer's Avatar
I will be running a 150 shot....I was originally going to stick with the stock pistons and rods and just throw my motor back together but I have hit every road block so I said screw it and I want to order rods and forged pistons...it made 568 to the wheels with the stock stuff...and I found a steal on the rods ...so I figured why not
Old Mar 21, 2013 | 09:02 PM
zrmurcer's Avatar
Old Mar 21, 2013 | 10:44 PM
Burken01's Avatar
yeah a forged rod/piston combo is good to have because when you want more power you don't have to worry about your bottom end..
Old Mar 22, 2013 | 05:05 PM
zrmurcer's Avatar
I got it all ordered today...
Old Mar 22, 2013 | 05:20 PM
Burken01's Avatar
what did you end up getting?
Old Mar 22, 2013 | 07:29 PM
zrmurcer's Avatar
I got mahl pistons and those eagle h beams...should be here Tuesday then I take it all to the machine shop to get my cylinders honed, crank polished, and get the rotating assay balanced
Old Mar 22, 2013 | 07:30 PM
zrmurcer's Avatar
I am ready to here this thing run again!!!!
Old Mar 22, 2013 | 08:44 PM
Burken01's Avatar
nice, goodluck with your build... post up some photos when your done...
Old Mar 22, 2013 | 11:31 PM
zrmurcer's Avatar
I will do it thanks for the info....that's why I like this forum...just a bunch of car freaks help in each other out....thanks again
Old Mar 23, 2013 | 12:08 AM
Burken01's Avatar
yea usually, stuff gets outta hands sometimes also.. But just remember this is the ''internet" and half the things you hear are wrong lol
you just have to back it up with some research on your part too ya know!
Old Mar 23, 2013 | 09:48 AM
zrmurcer's Avatar
Yessir...I basically just wanted a second opinion before I bought every thing...just to be 110% sure
Old Mar 23, 2013 | 09:51 AM
zrmurcer's Avatar
I do appreciate all of your info!!
