Critique my LS1 383 plans
How much taller, precisely, is the truck manifold vs the regular 102?
This is what I plan to emulate with my build: https://ls1tech.com/forums/conversio...onversion.html
I'll contact Mike to see how much hood clearance he has. But it looks promising from the pics. The truck manifold might be the way to go.
Jake: My springs are PAC 1219's.
Martin: Thanks for the info. I definitely plan to use Morel lifters. They have served me well with my 461 Olds. Also, I do not already have a FAST92. I have no LS intake right now.
1998silverbird: Thank you for the info. I am aiming for around 550hp. But more is never a bad thing.
If the 102 will make more power without hurting the low end of the power band, then I'll buy a 102.
So I am hearing some in favor of the 92 and others in favor of the 102. Other than the FAST intakes, what are my other options? I want to stick with FI, not carburetor. And it will have to fit under the hood of a Daytona coupe...so it can't be too tall.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
If you have the money then get the fast setup, if you dont then Typhoon is a option. I made 5-15 hp more then my LS6 intake throughout the powerband.
