PTV clearance?
Old Mar 23, 2013 | 08:12 AM
Dvldogyut's Avatar
Default PTV clearance?
Im ready to order pistons for my build. Its a daily driver. With a slight chance of a 200 shot once and a while. I have a 6.0 iron block bored .030 with ls3 heads. I have a bullet racing cam that is 288/299 with .620/.625 lift. Will I need any valve relifes if I run a flat top piston?
Old Mar 23, 2013 | 10:22 AM
PREDATOR-Z's Avatar
What is the full specs at .050 with lsa+icl
Old Mar 23, 2013 | 12:13 PM
JPH's Avatar
JPH
Most aftermarket LS pistons have valve reliefs in them already, so that will be a plus for you and have plenty of PTV then. The reliefs will also add volume though, so make sure you refigure your SCR.
Old Mar 23, 2013 | 12:56 PM
JakeFusion's Avatar
Super Hulk Smash
I'd make sure the pistons are cut for LS3 heads as well. Otherwise, you may run into PtV problems. But almost all aftermarket shelf pistons have valve reliefs in them and would require a custom order for true flat tops.
Old Mar 24, 2013 | 03:39 PM
Sales@Tick's Avatar
As has been already said, with aftermarket pistons 90% of them have a large enough relief to run almost anything.
