4.8 to 5.7 swap
My question is, will I be able to use all my existing 4.8 accessories? like oil pan, intake (probably upgrade, but like to know the stocker will work), coils, injectors, pulleys, exhaust?
If not what is needed for this swap?
I did a search for 4.8 to 5.7 swap, swap, 4.8 swap, and 5.7 swap, but found no useful info. I'm sure you guys deal with us truck guys stopping in here all the time with these questions so i apologize in advance if you cover this info a lot. Is there a sticky that I missed?
Thanks
Second if I were gen 3 engine shopping the 5.7l would be nowhere near the top of the list of choices to look at.
In most areas you can find a 6.0l much cheaper, stronger block, that can be bored out for any future repairs or performance build and the heads flow more, as I already said the truck intake is better than the LS1 intake.
Hell a LOT of guys with cars that came with the 5.7l get rid of them in favor of truck blocks.
Believe the truck coils are considered better than the LS1 ones as well.
What year is your truck? This plays into what year engines would be easiest to swap in.
Don't go BLINDLY drooling over car parts, they aren't necessarily the upgrade you would assume
Good to know about the intake and coils, thanks.
Will the 243 exhaust ports require a larger diameter header?
What are the chances an old 4l60 will hold up behind either of these engines?
I don't think I have seen one here for less than twice that.
the 4L60E can handle a lot more than folks think, now whether your 4L60E can handle it nobody can say.
I've got some measurements from the sticky, so I know the stroke should be 3.662. That will tell me its a 5.7. I plan on spinning the crank to make sure it moves freely, and checking the bores for signs of damage. I also plan to pop a main and rod cap and take a look at the bearings.
At this price, I would think its going to need a rebuild, but what are the chances I could get away with a hone, new set of rings, and bearings?
This will get 243 heads and a custom truck cam, and be a mild daily driver.
Am I crazy for considering a cheap rebuild to last 100k miles? I only want about 380whp...
I was thinking of marking all the rods, caps, and main caps, and breaking it down. Then cleaning everything and installing new bearings and rings after a quick hone on the cylinder walls.
Does anyone think this is a terrible idea?
at the very least I wanted to break it down and clean everything, get it lubed up with clevites bearing guard.
