402 Teardown, engine experts welcome
Old Mar 24, 2013 | 12:43 PM
Atomic's Avatar
I need a gauge for that
Default 402 Teardown, engine experts welcome
Noticed low oil pressure and cut open the oil filter and saw a lot of bearing material so decided to pull the engine sooner rather than later. Roughly 3500 miles on it...granted those are hard miles Engine was still running great! No odd sounds, no vibrations, still making great power, no smoke, no oil consumption. Just low oil pressure and bearing material. Engine was built by a very reputable shop in Houston.
Anyway, on to the pics...
Just put in new plugs as well...if you notice 2 timing marks, I pulled 2 degrees out before the last time I ran it. Most timing was around 17 degrees.
Top end looked great to me. Zero evidence of detonation.
Cylinder walls look good...
Then the party starts...
Old Mar 24, 2013 | 12:45 PM
Atomic's Avatar
Rod bearings, cyl1 on the left.
Main bearings, 1 on the left.
I think we found a winner!
Here is number 2....this doesnt quite seem normal...
Main journal 1,
Journal 2,
Journal 3,
Journal 4,
Journal 5,
Looking at cylinder 7, notice the bearing material hanging out...
Block journal 1,
I havent pulled the cam yet, because frankly im not sure how to pull out the cam bearings out besides with a screwdriver. The cam lobes look fine though.
Normal oil pressure was around 60ish, with 80+ at WOT....noticed the gauge sitting around 40cold, then dropping to 30 hot with barely any increase with rpm.
this is the second engine this crank has been in that has exhibited the exact same thing. Only things reused were the crank and rods...
Here are the mains from the 408 this crank was in first...
Mains were set to 0.0027, and rods were 0.0025. Used 10w30 and 20w50 brad penn oil.
Checked runout this morning...
Main1: 0.001
Main2: 0.005
Main3: 0.004
Main4: 0.001
Main5: 0.001
I thought the factory spec for runout was in the 0.007 range...
Here is a video of number 3:
Edit: Everything Ive found says max runout for main journal is actually 0.0003"
Old Mar 24, 2013 | 01:45 PM
96lt4c4's Avatar
Wow! I would be pissed. What crank is that? Looks bent to me. I would be calling whoever built it. I plan on checking all my **** when it gets back from the machine shop. Your block may need to be line honed, and that crank? Not real sure. I would think that someone could straighten it out, then have it turned .010.
Old Mar 24, 2013 | 01:58 PM
redbird555's Avatar
I agree the crank looks like it might be bent. I'd have the motor torn down, block looks like it needs a line honing. As for the crank though idk if I would even want to straighten it, I know its a stroker one and all but I'd feel better with a good used one or new one especially when you have that much tied into the engine.
Old Mar 24, 2013 | 02:07 PM
Atomic's Avatar
Crank is a K1 forged 4"
Yea I plan on calling the shop monday. But really, I dont know if this would be a machining issue or just the fact of pushing beyond the limits of the part. I was pushing above 1k hp at the engine im sure. All journals should have been turned/polished which I believe were. Leading theory now is the crank is bent or cracked. Regardless, I am not reusing this crank again.
Old Mar 24, 2013 | 02:16 PM
96lt4c4's Avatar
Same crank going in my NA 402, didn't know you were making that kind of power. Hard to say then, maybe it twisted or bent.
Old Mar 24, 2013 | 02:29 PM
ckpitt55's Avatar
Did they line hone the block after the studs were installed? Was the crank blueprinted and was the runout checked?
Old Mar 24, 2013 | 02:48 PM
Atomic's Avatar
Yes, yes and yes it should have been.
Old Mar 24, 2013 | 06:42 PM
garygnu's Avatar
looks like some one poured kitty liter into the oil pan .the plugs and pistons look ok.the bearing and crank mains don't look good.maybe regrind the crank and new bearings ?
Old Mar 24, 2013 | 09:54 PM
Atomic's Avatar
I am definitely not using this crank again...pretty sure its bent/cracked.
