What exh valve size?
In the "old days" (10 years ago), everyone used the 2.02/1.60 combo. Now I see everyone using 2.02/1.57. Why the change?
Chris
But, I'd say exhaust port velocity is improved with a smaller valve. The 1.60" valve and 1-3/4" headers worked well together, but a 1.57" and 1-7/8" combination may work even better.
I had asked that question a few years back with the TFS heads, and no one knew for sure, but they seemed to respond well to a larger header. The speculation was because the port was efficient at evacuating the gases at a higher velocity, you just needed to have enough exhaust/header piping behind it to support the overall flow.
That and a 1.57" valve weighs less and provides more PtV clearance.
http://en.wikipedia.org/wiki/Venturi_effect
Also relevant:
http://en.wikipedia.org/wiki/Choked_flow
Also, I went with bigger valves in my head, but did hollow-stem. Because, well, unless you have Z06 243s, you have solid stem 2/1.55" valves. And the aftermarket stainless valves are only a few grams heavier.
