Stealth II soundclip
Sure, I could take another clip showing some revs. Not saying I'll do it today, however.
Sounds cool btw
I kid you not, this cam sounds even smoother in person than it does on the recording. No shakes, no shimmys. The only way I can get it so that you can plainly tell that there's a bigger cam in there is if I open the cuttout AND lower the idle down to like 525 RPM.
hold your breath for this one hehe jk I kid you not, this cam sounds even smoother in person than it does on the recording. No shakes, no shimmys. The only way I can get it so that you can plainly tell that there's a bigger cam in there is if I open the cuttout AND lower the idle down to like 525 RPM.
I love the sound, I didnt buy it to be quiet but to idle smooth inside the car and its great . After install it fired right up , tried to die for about 3 seconds and then just idled away. Ill have track times at the end of the month and some dyno numbers as soon as I get it off jack stands . Im hoping for close to 380 - 390 rwhp
Tony
hold your breath for this one hehe jkJoeDirt, could you send me that soundclip? Or post it or whatever.
ulysses_nilo@hotmail.com
Thanks
**edit** Nevermind, I found your clip, sounds nowhere near Colonel's car.
Sounds really good though!
I found your clip but it didn't work for me.
It has stock heads, Kooks long tubes, kooks catted Y etc and was installed straight up ( checked and double checked) .
Is it possible it was an erlier version with maybe a more aggresive spec ? Because I bought it used I didnt get a cam card .
Ill try to find the vid and post it again. Its not very good, just taken off a digital camera but you can hear it chop
So what's the idle RPM?
http://www3.telus.net/public/a7a74501/stealth2b.mpeg
