LS1 Pre-Rebuild Questions
Old Mar 30, 2013 | 06:31 PM
Atdc94's Avatar
Default LS1 Pre-Rebuild Questions
Hey everyone. I wasn't sure where to post this. If I am in the wrong section, please guide me to the correct section. I am thinking of rebuilding my LS1 engine in my 2000 Camaro Z28. Ever since I bought it it has had an oil leak, but it is progressively getting worse. If I do end up rebuilding her, I want to do it right, and i don't want it to go back into the car stock. What do I need to make 400+ horsepower? Will my rear end and tranny be able to handle this increase in power? What is the best place to get parts? Thanks in advance everyone!
Old Mar 30, 2013 | 07:20 PM
garygnu's Avatar
Texas Speed and the ws6 store are some places to start looking at for parts.how many miles on the motor ?maybe you only need some new crank seals .get a ls6 intake and a ported TB.have the heads freshened up ,and consider a TSP torquer v2/3 cam shaft.buy the cam pkg.you will need a 3500 rpm stall .you rear and trans should handle the power ,rebuild the trans if over 100k miles.get a trans cooler and a deep trans pan .consider some comp cam trunnion bearings for the stock GM rockers.
Old Mar 30, 2013 | 07:25 PM
Atdc94's Avatar
The motor has just under 108k miles. And I'll check those stores out. Thanks.
