To much oil pressure?
Old Apr 8, 2013 | 08:56 PM
VandykeT/A's Avatar
Default To much oil pressure?
On a cold start my car will go to around 75 psi and with throttle will peg the gauge. Normal driving cold I get the 75ish psi. Hot I get around 60lbs and driving I get roughly 65-70. This is with a ported TSP LS6 pump, stock pan, pick up etc. Its a heads/cam car stock bottom end. Before the pump the car kept 60lbs on a cold start and 40lbs hot. Is this normal?
Old Apr 8, 2013 | 11:20 PM
Fosnot's Avatar
what weight of oil are you using....
Old Apr 8, 2013 | 11:23 PM
low2001gmc's Avatar
MASS seller approved
i got a similar situation with a melling 296 oil pump and stock pan....
Old Apr 9, 2013 | 09:58 AM
VandykeT/A's Avatar
I was using 5w30 but since it was going to be living at high rpm most of the time I started using 5w40 rotella T6. It only really effected the pressure on cold start if I gave it slight throttle and it was very little of change. Just seems to take a little less throttle to make it peg the gauge. And by throttle I'm talking less than 2k rpm.
Old Apr 9, 2013 | 04:46 PM
farmington's Avatar
you'll make more power on 5w-30.
Old Apr 9, 2013 | 06:23 PM
Gray86hatch's Avatar
I would not be worried. My dads car is similer to that. My car makes way more than that with a big high volume pump.
Tim
