LS1 to LS6 PCV conversion
Old May 29, 2013 | 12:10 AM
Kurt D's Avatar
Originally Posted by roastin240
Is an oil catch can unneccesary w/ the LS6 valley cover? I have both which is why I ask.
It's necessary on all LSx motors to reduce/prevent oil consumption. My LS3 has the newest style PCV and with 800 miles on the OD there was oil in the line and front of the intake.
Old May 30, 2013 | 03:19 PM
smws6ta's Avatar
Can't hurt it and I run one with mine.
Old Jun 22, 2013 | 04:47 PM
00_MMM_Z28's Avatar
Slight revival, does my 2000 need the 01 and newer crossover tubes or is there a way to modify my stock ones?
Old Jun 23, 2013 | 07:38 PM
Roarin_8's Avatar
What crossover tubes are you talking about, coolant lines?
I have a 2000 and the only tubing that I got was the one that was on the first page.
Old Dec 10, 2013 | 06:03 AM
Patsy57's Avatar
Bringing back the old thread, would an LSX bow ties block require cutting for the LS6 PCV system?
Old Dec 10, 2013 | 10:14 PM
2002 blue z28's Avatar
You only need the 01+ crossover tubes if you are using an LS6 or FAST intake. However, some people have had success slightly smashing down the 98-00 tubes.
No you don't need to cut the block.
Old Dec 11, 2013 | 04:40 PM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
I've seen more cracked FAST intakes with people trying to smash down the coolant tubes. Don't cheap out. Get the LS6 tube and block offs.
Lonnie
Old Dec 11, 2013 | 04:48 PM
JakeFusion's Avatar
Super Hulk Smash
So I just dropped my motor back into the car without the FAST on it, but I did the grinding and installed the LS6 PCV.
Are the 02 LS1 coolant fittings no good? I haven't tried to test fit yet. But I don't recall there being any sort of crossover coolant port when I uninstalled the LS6 intake. Were the crossovers LS1 only or am I just not remembering what I did when I tore the motor down? If so, I will just go with Kurt Urbans steam port setup which is much much cleaner.
Edit: nevermind. I went out and looked in my parts bin. The LS6 had a rear crossover pipe. I still might do the Kurt Urban setup tho...
