Cheater Cam
FYI, the 224/224 112lsa cam is to big (0* overlap), You need at least -4* overlap overlap; preferably more. Id also consider having the factory heads milled and ported or buy some SMOG legal performance heads like the AFR210s. With high flow heads you can go with less split like a 218/226, then you also can go with a narrower lsa like a 115 but still have -8* overlap.
