Biggest cam without notched pistons
yup. I know FTi (ed cutris) dose some big cams New Era sell, and Ive used. Little bigger then a Trex, "Hellion" 244/248 .630/.630 cam and is on a 112 LSA its close under the "normal" PtV clearance min spec you read about in the internet. But like a Trex runs fine, and some times if you take the heads off the car, you might see some light contact marks from the intake valve on the piston. But the engine was running fine, the valves, and piston have no damage from it.
http://www.streetfire.net/video/1999-trans-am-cammed-ws6_138027.htmhttp://www.streetfire.net/video/2005-gto-et-heads-and-hellion-cam-by-edcfull-b_81761.htm
