Oil Priming
Old Oct 27, 2013 | 01:59 PM
schnellttz06's Avatar
Originally Posted by badazz81z28
The point is, this home made tool works and puts a few dollars back in your pocket. I couldn't get my self to spend the money to use it once.
Fair enough, but most people really don't want to go chasing parts down to rig something up, and after you spend five to ten grand building an engine, what's another 79 bucks. And hey, you can get it and use it once then throw it on ebay, Ive done that plenty with tools.
Old Oct 27, 2013 | 05:33 PM
Paul Bell's Avatar
That's MISTER MODERATOR
To re-locate your OPSU, you need to setup a kit like this. It's from a non-sponsor so I won't say who. You need an adapter from whatever the thread on the OPSU is to like -4 AN, a length of hose and an adapter back. The gauge shown is optional and not needed-unless you want it.
Old Oct 29, 2013 | 12:35 PM
KTOWN's Avatar
badazz81z28, do you have the part numbers for the fittings that you used ? I looked in the summit book but could not find them.
Old Oct 29, 2013 | 02:29 PM
Paul Bell's Avatar
Mike Noonan's (the owner of EFI Connections) book about EFI stuff has a listing of oild pressure sending units and their thread sizes. I'll look up what's needed later after ''work''.
Old Oct 30, 2013 | 08:38 AM
Paul Bell's Avatar
Old Oct 30, 2013 | 09:17 AM
wildcamaro's Avatar
Nice diagram man
Old Oct 30, 2013 | 12:05 PM
Paul Bell's Avatar
I'm an arr-teest.
I'm gonna print it and stick it on the refrigerator.
Old Oct 30, 2013 | 12:10 PM
Paul Bell's Avatar
If there's a -4 socket to 16MM x 1.5 female adapter out there, this could be done using the original LS metric OPSU. That would save the 55 + bucks on the 8.1L unit.
If anybody finds this fitting, let me know.
Old Nov 7, 2013 | 11:57 AM
KTOWN's Avatar
badazz81z28,do you have the part numbers for the fittings that you used?
Old Nov 17, 2013 | 11:08 AM
Bama99z's Avatar
Very Interesting info here guys. My short block was assembled with moly lube, however I think that I will be going the hand pump route. Dont want a dry start up!!!
Old Jul 29, 2014 | 04:06 PM
sirhk100's Avatar
For anyone that stumbles on this... On my LQ9, the port on the drivers side front of the block is a M16-1.5 thread. Just a FYI... This isn't a "I think mine is..." post, it literally is... I bought the part today and threaded it in by hand fully seated.
Going to pull the valve covers probably this weekend and give this a shot, I've got all the fittings in hand to knock it out...
Old Jul 29, 2014 | 04:14 PM
  #32
Paul Bell's Avatar
Hey, I can add to this. Here's my version of relocating the OPSU:
Old Jul 29, 2014 | 04:17 PM
  #33
Paul Bell's Avatar
And here's the oil pressure & leak test I did. 15 seconds cranking, no spark plugs:
Old Jan 22, 2015 | 09:37 AM
  #34
weeble1's Avatar
Bump this from the dead. Lots of good info in here. Thanks guys.
Old Apr 8, 2015 | 07:58 AM
  #35
mightyquickz28's Avatar
Definitely a help. I'll be firing up my turbo 5.3 pretty soon. Glad I found this thread...
Old Apr 8, 2015 | 06:36 PM
  #36
bayer-z28's Avatar
Originally Posted by 3rdCoastPowerSports
you can turn it over with the starter for a few seconds at a time (ignition and fuel system disabled of course) until you get pressure then fire it up. Best is to use a pre lubber though. The one in the picture would work great and I like the inventiveness. I personally use the Kentmoore Pre Lubber (looks a lot like the one a few posts above).
I've done this after a couple HC installs. I just pull the Fuel pump relay and I plan to do it again after my LQ4 top end rebuild.
Old Apr 16, 2015 | 08:06 PM
  #37
Thanks guys for posting this. I used your suggestions and primed my new all forged 5.3 today.
Old Apr 16, 2015 | 08:39 PM
  #38
RockinWs6's Avatar
I wnt to add a warning to this thread. If you build this DO NOT USE Teflon thread tape on the fitting. Go buy the liquid thread sealer or use nothing. That thread tape can cause ALOT of problems if even a tiny piece gets into the engine oil system. It is only for water systems.....don't say no one ever 4 warned you.
Old May 13, 2020 | 10:16 AM
  #39
TTA1437's Avatar
Old thread but good info here. Do you rotate the crank shaft during the priming process to lub all bearings for rod, crank, and cam? Im also assuming that the lifters will bleed oil onto the cam lobs as well.
I used the garden sprayer technique. I highly suggest using the port by the timing chain. If you dump oil into the oil pressure port, you are bypassing the filter (bad if there is a contaminate in your oil or pressure device.
The AN fitting and reducers are about $20 from Summit. M10-1.5 and -4 and -6 AN
Attachment 609367
Attachment 609368
