cam for a truck?
What gears, tire size, and are you considering a stall?
Currently have 245/75/16's, 4.10 gear and stock converter. I may put on bigger tires at some point down the road and a programmer. I have a cold air intake and cat back exhaust now, but everything else will remain stock
An aftermarket cam requires custom reprogramming immediately period. If you think otherwise don't mess with the engine atall.
to the OP, have someone do a custom tune for you when you do the cam and/or heads swap.
http://www.ws6project.com/user_stor/...oducts_id=4626
http://www.cammotion.com/LS-Hydrauli...-P146C202.aspx
If you are keeping the rest of your engine stock, I would pick an off-the-shelf grind using the selection criteria on Comp's website.
