Milled 5.3 heads; pushrod question?
Old 04-23-2004, 10:28 AM
ss1le02's Avatar
Default Milled 5.3 heads; pushrod question?
If I'm milling my 5.3 heads 30 thousand can I still get by with the stock length pushrod? I'm rebuilding my LS1 with Diamond forged pistons. The new pistons are the stock replacement.
Old 04-23-2004, 10:37 AM
Kevin 276's Avatar
.030 is cutting it close...how much lift does your cam have?
Old 04-23-2004, 11:11 AM
ss1le02's Avatar
The cam has .581 lift on both I/E. I noticed that these Diamonds have a slight dish to them. They aren't perfectly flat like the stockers were. Due to this I think I should be all right with the P/V clearance.
Old 04-23-2004, 01:13 PM
Kevin 276's Avatar
I think you have a perfect cam which should clear. The absolute best way to tell however, is to clay it before you bolt everything down.
