HEELLLPPP!!!!! oil pump replacement
Old May 3, 2013 | 02:21 AM
TexasGMC08's Avatar
If your going to change out the oil pump get a oil pump from a dod engine they put out more pressure then a hv pump 18% is not much hv. Oil sending unit might be bad change it out for $50. Yes you can reuse gasket on the pan if you dont want to reuse gasket drill out the 2 rivets that hold in place send the $50 and buy a new one...
Old May 3, 2013 | 11:48 AM
98cobrakiller's Avatar
can i drill out the rivets without dropping the pan completely though. plus if i use the dod pump it will work fine on the stock ls1 and not suck the pan dry
Old May 3, 2013 | 12:01 PM
sreve's Avatar
cradle comes down to swap the gasket.
I've had mine down 3 times still using the orig. gasket, no leaks.
Old May 3, 2013 | 12:57 PM
WS6ICK2k's Avatar
What is a dod pump exactly? Sorry to hijack just never heard of them.
Old May 4, 2013 | 02:16 AM
TexasGMC08's Avatar
Originally Posted by 98cobrakiller
can i drill out the rivets without dropping the pan completely though. Plus if i use the dod pump it will work fine on the stock ls1 and not suck the pan dry
you have to take off the pan or you will drill a hole in your block...
Old May 4, 2013 | 02:19 AM
TexasGMC08's Avatar
DOD "DISPLACEMENT ON DEMAND" ENGINE's THE OIL PUMP's PUT OUT MORE OIL PRESSURE THEN A NONE DOD... YES IT WILL WORK WITH YOUR LS ENGINE ALL PARTS ARE INTERCHANGEABLE FROM A 4.8-6.2..
Old May 4, 2013 | 02:35 AM
TexasGMC08's Avatar
Also the dod "displacement on demand" oil pumps put out 35% psi more then a none dod oil pump and a hv oil pump puts out 18%.so the dod pump is the way to go.
