Push Rod length and Preload on LS7 lifters
Old Apr 22, 2013 | 09:03 PM
vmapper's Avatar
Default Push Rod length and Preload on LS7 lifters
Would like people's opinion on what preload is good for a Blower cam and LS7 lifters.
With the shims required for the YT 1.7 roller rockers to get a center wipe on the valve stem... the pushrod checker ended up being 12.5 rotations and left just a tiny click with the rocker.
6.800" x (12.5 rotations x 0.050") = 7.425"
Which pre-load is better?
~0.075" preload requiring a 7.500" pushrod pn 7957-16
~0.050" preload requiring a 7.475" pushrod pn 7797-16
Old Apr 22, 2013 | 09:22 PM
poltergeist 02's Avatar
Zero lash would be when there is no slack left in the rocker. From what I have read about LS7 lifters you should run about .080 preload (which is about half travel of the plunger inside the lifter) for a quieter operation. I started at .058 - .067 preload and I still had some lifter tick. Then I stepped it up to .083 - .092 and the lifter tick was gone.
Old Apr 22, 2013 | 09:26 PM
outkast6991's Avatar
I'm running .030 and the valve train is dead silent
Old Apr 22, 2013 | 09:33 PM
vmapper's Avatar
Okay... I just checked the Intake valve and it looks like it needs more pushrod than the exhaust (another 0.025)?
looking at all the valves, it appears that the Exhaust has a higher stem vs the intake? wtf...
has anyone come across this issue?
Old Apr 22, 2013 | 09:52 PM
Either vj difference or 2 different stem lengths. If they are that far apart I'd run different pr's for in/ex
Old Apr 22, 2013 | 09:53 PM
I have the same thing with my heads (running manley valves). The intake valves sit .025 lower than the exhaust valves. I'm running two different length pushrods.
Old Apr 22, 2013 | 09:54 PM
How did you measure? Pushrod length checker? Also what cam and lobes?
Old Apr 22, 2013 | 10:02 PM
vmapper's Avatar
vj? sorry, not sure what that stands for.
I never noticed this.. brand new set of V2 AFR 230cc heads... are they not all supposed to be the same stem length?
hmm...
Attached Thumbnails Push Rod length and Preload on LS7 lifters-20130422_205601.jpg   Push Rod length and Preload on LS7 lifters-20130422_205630.jpg   Push Rod length and Preload on LS7 lifters-20130422_205708.jpg
Old Apr 22, 2013 | 10:05 PM
vmapper's Avatar
Measured by the turns on the comp cam checker to cyl 1 on the TDC (fire), added the shims to the roller rockers, when there was no more play counted the turns... Exhaust took 1/2 less than the Intake... looked at the stem, notice they sit higher on the exhaust. Rotated engine slightly both ways to make sure was on the small of the cam.
I measured using a Comp cams checker pn 7702.
Cam is a Brute speed Blower cam.
Old Apr 23, 2013 | 01:15 AM
RonSSNova's Avatar
To eliminate all the turns counting and confusion, I simply established 0 lash with the adj pushrod, removed it and measured end to end, added the desired preload, and ordered pushrods.
If going custom, you can get exactly what you want.
If buying off the shelf, might fall in between, so you have to decide less or more preload.
Alos, I noted at least on trick flow pushrods, they are .015" longer than stated when measured end to end. I just took that into account. I really think as long as you are between .050 and .080" preload, you are fine.
Clearly, the AFR heads use 2 different tip heights, so for sure, you will need 2 lengths.
Is my valvetrain silent? Nope. Too much spring for the LS7 lifters. I live with it. Compared to a solid roller....it's quiet!
Ron
Old Apr 23, 2013 | 03:00 AM
RQSGTO's Avatar
hmm...
VJ = Valve job.
Old Apr 23, 2013 | 04:12 AM
vettenuts's Avatar
The intake stem appears close to level with the retainer (may be the photo). Have you rotated the rocker through the entire lift cycle to check clearances with the retainer, etc.? I would do this with a check spring by hand.
Also, not sure how much shim you used but on my AFR's it took a 0.125" shim to get a good wipe pattern. The shims that came with the rockers weren't thick enough as the AFR valve stems were a little longer than stock.
Old Apr 23, 2013 | 05:34 AM
SMOKNSS's Avatar
This is what I have been doing for years. never had an issue.
Old Apr 23, 2013 | 10:00 AM
vmapper's Avatar
Good idea, the intake stem are closer, not sure if all clear the retainer, cycling will be a good idea.
Yes, shim was 0.110", however, this would vary due to valve stem height. The shims with the YT were definitely not enough.
Also it would mean i require a 7.550 - 7.600" rod. you cant buy 0.025" lengths after 7.500".
Old Apr 23, 2013 | 10:36 AM
You can buy any length from manton, smith bros, or trend
Old Apr 23, 2013 | 08:44 PM
^^^^ this
Old Apr 24, 2013 | 04:09 AM
vettenuts's Avatar
Not sure I understand but it sounds like you plan to run a different shim on the intake and exhaust rocker. You must run the same shim thickness on the rocker pair. Since wipe doesn't change a lot with small shim thickness changes I would try to pick a shim that provides the best wipe on both valve stems. Once you have the shim figured out, then install the rockers and measure for pushrod length.
Also, with a 0.110" shim, you will either need to provide a lot of clearance in the rocker covers or get 1/2" spacers. I am running a 0.125" shim and need to remove all the baffles an bosses inside the valve covers. It was a lot of grinding. If I had it to do over again I think I would have tried the 1/2" spacer first.
As far as pushrod length, you can get any length you want. Manton will make them easily and I would go to 11/32" OD as well. Note that Manton uses overall length for measurement. Trend will also make custom lengths and was where I got my 3/8" double taper pushrods. I wouldn't worry about the final length, you can get whatever you need just not from the vendors who only stock off the shelf sizes.
