5.3 to 5.7 worth it?
Also, pistons, i was planning on running Speed-Pro as this motor will never see spray or boost. Mostly street driven, very occasional pass at track. Think the Speed-Pro's are going to fit the bill, or should i step up to Mahle pistons? I know for a fact i won't need a full forged piston. I was planning on running a Scat I-beam rod, simply for the ARP bolts, just not worth installing in a stock rod, IMHO. Was planning a press fit rod, should i go floating, since the price really doesn't change?
Sorry for so many questions, but my mind is going crazy, looking for outside thoughts on this. LOL
No need for forged rods or pistons on a NA 5.3 or 5.7, but ARP rods bolts will deff help if you plan to shift at a high rpm.
Summit does not do the machine work to the ls blocks they sell... They buy them from gm and still in the gm crate when they get to summits wearhouse.. Ive called on them before. Also they dont know if the knock sensors are on the side or in the valley until you open the box...
