LS1 spun bearing, need advice if I should rebuild it or not
You can buy a low mile gen 3 6.0 for real cheap. Cheaper than rebuilding the LS1. The SS Camaro you can find in a lot of places, but non with a nice 6 liter in it. The down side is that the block is about 80-90 pounds heavier than the ls1, but you will gain that nice power out of it. If you plan to keep the car forever then I would swap to a 6.0 iron block
We can get you a 5.7 for as little as $1619 to get you mooving again. We have dozens of options to upgrade and will allow for more power as well. Give us a call and we can get you set up driving your SS again.
Well an obdII pcm check wont show anything different, and a stock 6.0 will still pass a sniffer. Your only issue would be a visual check, but (at least in texas) the most inspectors look for on obviously modified modern domestics is cats. None ever look at block markings. Fwiw though, I hate taking iron blocked fcars over speedbumps. Thats just me though.
dunno, i'd have to ask but I know he doesn't have the parts
Are they really that annoying to go over speed bumps? lol
#32
good choice. keep the SS with factory LS1 engine, and mod later when you have the means.
Another option would be to temporarily drop in a 4.8/5.3 engine just to get you back on the road. They can be bought for less than half the price of a 6.0. That way you could take the time to re-build your LS1 right with good components.
#35
<- Steve from dcsportbike.
You don't need to worry about emissions, as long as you don't have a check engine light and all readiness codes are set correct it will be fine. Most places don't look for air/egr or even cats they just plug in. Also my car is "garaged" in a county that does not require emissions. That's very easy to do. I still wouldn't put a boat anchor in the front my car no matter how cheap they are. For big power it's a no brainer though.
$1600 for fresh ls1 is a great price btw. I'd tear down the car to access how much damage has been done then go from there. Sending you a PM now.
