How does my setup sound like?
Old May 2, 2013 | 12:35 PM
Z28Dave's Avatar
Default How does my setup sound like?
Alright so i finally pulled my head out of my *** looking and researching for a heads cam and intake setup and now it is done and i'm pretty sure i have everything.
TSP STG 2.5 5.3 Heads (not LS6 sorry)
EnglandGreen mayhem II cam
7.400 chromoly pushrods
Fast 90/92
37lb injectors
whats my powerband going to be looking around? M6 with 3.73s
i'm hoping for around 430 to the wheels
Old May 2, 2013 | 01:32 PM
HCI2000SS's Avatar
First let me say don't get caught up on dyno numbers. Secondly, you should probably reach peak hp around 6200 or so rpm, and carry pretty flat till 6800 or so. Sounds like it will be fun
Old May 2, 2013 | 01:51 PM
ckpitt55's Avatar
don't buy pushrods until you measure what you need.
Old May 2, 2013 | 02:03 PM
Z28Dave's Avatar
Well the push rods came in the the Cam package from EnglandGreen same with the springs for the heads sooooooooooo it was the recommended length for the cam
Old May 2, 2013 | 11:03 PM
JakeFusion's Avatar
Super Hulk Smash
The cam kit most likely is for stock heads. Once you swap heads and gaskets, you won't know your pushrod length until you measure.
That being said, what are the specs of the cam? Does EG release the specs? I thought that was a 240/240 camshaft. If so, that thing will peak around 6400 (because, well that's where all FAST 90s peak due to the runner design of the intake) - but it will probably carry well past that.
It'll have very little bottom end due to the size. And I'm assuming your heads are unmilled to fit the cam? If so, that doesn't help - you need to raise the compression quite a bit for that combo to shine. Flycut and mill the heads. Hell, you might need to flycut anyway to fit that cam with those heads and larger valves.
Old May 3, 2013 | 12:37 AM
Burken01's Avatar
In for specs? That's a big cam, it will eat a MS3 for breakfast if its really 240/240...
I guess the other thing to ask now is what lobes is it ground on?
Old May 3, 2013 | 12:59 AM
JakeFusion's Avatar
Super Hulk Smash
I don't know if it's 240/240 - EG says this:
EnglandGreen Mayhem II Cam™ : formally our Monster Cam™, but now completely redesigned - and much larger! Duration is in the low 240s range.
Is that right?
Also saw Reckhart post this: 23x/24x 0.63x/0.63x 113 LSA.
So it could be 230/240 113 at which point, it'll actually be a decent cam.
Old May 3, 2013 | 06:06 PM
Z28Dave's Avatar
Well englandgreen is shipping out the cam today so come around monday when its expected to come in i'll post up the cam card
