Need help with heads decision
Old May 5, 2013 | 01:35 PM
chad2775's Avatar
Default Need help with heads decision
I was about to pull the trigger on a set of afr 210's, but after doing research i would also need after market. rockers because of the valve guides, is this correct? If so that adds at least another $500, so is there a like head with the mid #'s of the afr's that you can use stock rockers? My goal is not a track car, I am wanting the power curve that the afr's have. Thanks.
Old May 5, 2013 | 01:39 PM
mac62989's Avatar
Ported 243s? Check out Advanced Induction or Total Engine Airflow both sponsors on here. They make awesome low/midrange power, their cheaper than the AFRs, and since their a stock ported head you can use stock rockers.
Old May 6, 2013 | 02:57 AM
Paul57's Avatar
What's the lift on your cam?? I have an email in to AFR and asked them about the life expectancy of the bronze guides and if it is possible to get Powdered Metal ones installed.
Old May 6, 2013 | 06:04 AM
chad2775's Avatar
I sent an email also, I will be getting a new custom cam but waiting on the head decision, trying to get everything matched good. Just dont really like the idea of another $500 for rockers..keeping my options open..
Old May 6, 2013 | 06:12 AM
TheWolfMatt's Avatar
You could try a set of used rockers in the classifiedes area. They do pop up from time to time.
Old May 6, 2013 | 07:52 AM
Dmitriy's Avatar
I have a shitton stock rockers
