Did the ls6 intake last night
Old Apr 24, 2004 | 04:22 PM
v8maro's Avatar
Default Did the ls6 intake last night
It is night and day on my car! I am so happy! YAY!
I did notice that my head ports were covered with a lot of oil, would this be because of the PCV system? Would a catch can help this a lot? I know I am burning oil now just by checking the dipstick, I am about 1qt low after 3k miles.
Thanks
-Steve
Old Apr 24, 2004 | 05:23 PM
offaxis's Avatar
Hey Steve
Be careful on beating the car after the intake swap. A friend of mine did the swap and it really leaned his car out and he needed to get a tune.
Old Apr 24, 2004 | 06:30 PM
pdd's Avatar
pdd
Catch can will help alot
Old Apr 24, 2004 | 06:54 PM
v8maro's Avatar
I kinda did already beat on it LOL The tune is set for the 29th, the thing is, with the LT's I was running really rich so I duno, maybe it evened it out?
Old Apr 24, 2004 | 07:05 PM
99-LS1-SS's Avatar
STF Veteran
Cool. I want to get a LS6 intake for my car.
Old Apr 24, 2004 | 07:11 PM
2000Z28M6's Avatar
mines waiting to go in very soon, just need to get some block off plates. V8maro how did it feel after the swap? Could you tell a difference in power? was it negligible? Any tips you might pass?
Old Apr 25, 2004 | 11:41 AM
v8maro's Avatar
Every RPM of EVERY gear is stronger, it's amazing. The car idles better, and the throttle is way more responsive. The power when I get on it is crazy I can't wait to get the tune, knowing I will only gain driveability and power from it makes me so happy!
As for tips, don't bother buying the front coolant pipe or the rear plugs. Save your $40! I took my stock coolant x pipe off and cut the front right after it merges, then used some pliers to pinch it. Got some solder and a blow torch and soldered it shut, works perfect (or you could get it welded at a local exhaust shop) Make sure you take the o-rings off the pipes before heating them up. Did that for the rear too. I also tested them by using an air hose (I am lucky my buddy has air tools )
Another tip is mechanics gloves
Also, there are little plastic nubs the stick down from the cowl that hold the rubber seal, remove those or your arms/hands will be cut up like mine.
And before you start the job, go rent a torque wrench from murrays that does inch lbs.
Other than that it's a very easy job, we could have finished within 3hours if we really wanted to
-Steve
Old Apr 25, 2004 | 03:48 PM
M6HuggerSS's Avatar
what were your dyno numbers before the LS6? and what mods?
Old Apr 26, 2004 | 11:04 AM
v8maro's Avatar
Welp, before the LT's, cutout, and ls6, I did 345rwhp with just lid, cam, heads. I was choking the engine pretty bad. The ls6 will probably net me 30rwhp with my other mods I will know what Lt's, orp, cutout, and ls6 intake net me on the 29th when I have a tune.
Also, the dyno number was on a mustang dyno...
-Steve
Old Apr 26, 2004 | 12:00 PM
stealth's Avatar
W2W just made 1150 hp through a LS6 manifold so it must be OK for us common folk.
Old Apr 26, 2004 | 01:26 PM
2001 HD's Avatar
Default LS6 Valley cover mod.
Has anyone tried the LS6 valley cover mod? Pretty cheap ($60.00) and vents the crankcase from the lifter valley instead of valve cover. Since you have the intake manifold off already. It's supposed to help the oil consumption. Or maybe try one of the Truck "Fixed orifice" PCV,s. 12572717 Dealer item-$3.61
Some minor block grinding required.
There is probably a technical article on it somewhere on this site.
Old Apr 26, 2004 | 06:11 PM
mcflyz28's Avatar
I've been debating on whether or not to get one Better get one while the wife is in a good mood and I haven't done anything to the beast in a month or so !!!!
Old Apr 27, 2004 | 10:42 AM
hourang's Avatar
hehehe woulda taken a lot longer without them
Old Apr 27, 2004 | 11:02 AM
v8maro's Avatar
yeah man, thanks, they helped a ton. Got all the intake bolts off within like 5 mins!!!
hourang's air tools
Old Jun 19, 2004 | 03:54 PM
INMY01TA's Avatar
I did the LS6 Valley Cover and it didn't help at all. Still got just as much oil in the intake as before. I'm using a catch can now and it works.
Old Jun 20, 2004 | 12:47 AM
busavette's Avatar
there a write up on intake& valley cover(and alot of stuff) at www.ls1howto.com
Old Jun 20, 2004 | 06:30 AM
apexman's Avatar
I just recently did an LS6 intake and Jantzer TB on my cam & header car. It made a BIG difference in the car. I can't wait to see the dyno results but have to wait as my car is in the body shop. My car was also running rich before and now seems to be about right. I would not be surpirised if I gained more than 10 hp with the swap, probably more the way it feels.
Derek
Old Jun 20, 2004 | 12:01 PM
HotRod68Camaro's Avatar
Im just goint o put valve cover breathers on which should eleminate the the PCV system all together.
Old Jun 21, 2004 | 08:55 AM
hourang's Avatar
Derek
be careful after the intake install he was running real lean up top, i would get it on the dyno to check the ratio.
