Switching cams????
Old Apr 24, 2004 | 05:16 PM
Z06PSI's Avatar
Default Switching cams????
I have a Schneider custom ground 234/230 .578 on a 112 and was going to switch over to this.
Comp XER 226/230 .600/.605 on a 111lsa....
Any opinions..??????
TIA
Old Apr 24, 2004 | 05:21 PM
offaxis's Avatar
What is the reason for the swap ? Im not sure you would pick up any power and if you did I dont think it would justify a cam swap.
Old Apr 24, 2004 | 05:26 PM
Z06PSI's Avatar
Just wanting to move the power down a little in the rpm band.....
Old Apr 24, 2004 | 06:05 PM
offaxis's Avatar
You can try a 112+4 like my current cam . My peak is at 6100 rpm
r1 cam specs 232/236 .575/578
My old cam was the tr 230/224 .575/.569 111 peak power was at 6500 with that cam
so now i make more power at a lower rpm with more duration.
Jeremy
