Checking clearance
Old May 8, 2013 | 03:02 AM
Paul57's Avatar
Default Checking clearance
Is there a good way to check piston to valve clearance without using clay??
Old May 8, 2013 | 07:51 AM
FIVEPOINT7's Avatar
dial indicator
Old May 8, 2013 | 08:14 AM
pauls99z28's Avatar
Here's something worth trying...
Originally Posted by Alvin@PCMofNC
Instead of using a dial indicator take some feeler gauges and set it up with how much P2V your looking for. If you can get that set of feeler gauges to fit between the valve tip and rocker arm between -15 degrees TDC to 15 degrees TDC you are good to go. Its much easier than using a dial indicator and I would argue more accurate especially when you consider your removing the chances for human error and dial indicator setup.
Old May 8, 2013 | 11:40 AM
Justhereforinfo's Avatar
Do you need to use the soft measuring springs when doing this? I could imagine with 450#'s of open spring pressure, it would be tough to force a flimsy feeler gauge in there...
Old May 8, 2013 | 05:19 PM
RezinTexas's Avatar
try this one
http://www.scribd.com/doc/137049285/...RAFT-20-Apr-13
Old May 9, 2013 | 02:19 AM
Paul57's Avatar
Could you post the information from Appendix X for calculating with indirect measurements?? I was not able to find it on your link.
