Oil pump going out?!
Old May 9, 2013 | 03:37 PM
1_MEANZ28's Avatar
Default Oil pump going out?!
Hello fellow ls owner ,hopefully you guys can help me out.
Car is my 98 camaro z28 ls1 181,xxx on her
I run mobile 1 10w30.
Oil pressure is good cold 50-55 hot 35 40..
Weeks ago i ran my car in the 1/4 assuming everything was good only had old plugs..got to run it 2 timea the second run when i was rolling to park it i noticed oil pressure droped and when going to park droped to 0.and it started knocking.turned it off fast..after thinking and thinking what mabe whent bad i turned it on approx 5 mins passed se statted and noise went away and pressure came back to 40..while running it preasure was at 60..
In my opinion the oil pump is going out.since its happened i have been daily driving the car.no problems what so ever not yet.been in the hottest weather in traffic and no problems..
Im not sure if oil is to thin or what?
Once again car drives very good good oil preasure.
Car does not burn oil nor smoke
Any inputs would be greatly appriciate it..
Old May 9, 2013 | 04:51 PM
jrpimp00's Avatar
oil pump doesn't go out and then start working again. id check sending unit and/or wiring
Old May 9, 2013 | 06:07 PM
1_MEANZ28's Avatar
Thought about sensor except for the part that when pressure whent to 0 it started knocking..soo sensor is reading fine
Old May 9, 2013 | 08:42 PM
SWEET98SS's Avatar
I had a problem with mine, the pressure relief valve in the oil pump stuck open, so it wouldnt build any pressure, It only took once to take out my bearings. I drove it a couple hundred more miles and then rebuilt it. My oil pressure kept getting worse. I would put a new pump in it, its a pretty simple job.
Old May 10, 2013 | 12:33 AM
1_MEANZ28's Avatar
A buddy told me mabe the motor has alot of varnish that explaining why at wot all oil goes up top and takes a while to go down due to the varnish..can that be true?
Old May 10, 2013 | 06:03 AM
SWEET98SS's Avatar
I have never heard of a varnish problem. Normally the gears dont break either and if they didnt, you would have oil pressure now. Cut your filter apart and see whats in it as well on your drain plug.
Old May 10, 2013 | 06:41 AM
poltergeist 02's Avatar
If that was the case you should be able to pull a valve cover and check if there is any build up in the heads.
Old May 10, 2013 | 08:38 AM
oange ss's Avatar
no varnish problem, if you're running synthetic
Old May 10, 2013 | 10:03 AM
1_MEANZ28's Avatar
The only problem is that i got the car like 2 months ago.and by the looks of it previous owner liked to take the camaro to walmart for oil changes..im sure they use the crappy oil..i was considering a seafoam ..put seafoam in current oil let it idke for a bit take t around the block change oil to crappy oil run it around the block again then drain it and do m1 again..
Old May 10, 2013 | 10:04 AM
1_MEANZ28's Avatar
I need to do that asap
Old May 10, 2013 | 11:39 AM
Bowtie316's Avatar
This is exactly what they do when the oil pump relief valve gets sticky.
Upon opening the relief valve during high rpm and high pressure, the valve sticks open. Then when lower rpms are reached, it is loosing pressure out of the stuck relief valve. Sometimes shutting off and cooling down is enough to unstick it as your did. I would get a new pump on it asap.
Old May 10, 2013 | 11:53 PM
1_MEANZ28's Avatar
Thanks for the info and yea im gonna order the tsp ls6 ported oil pump
Old May 11, 2013 | 08:42 AM
Bowtie316's Avatar
Might as well do a cam at the same time.
Old May 11, 2013 | 02:06 PM
1_MEANZ28's Avatar
Yea thats was i was Also thinking of .but since the car dosent even have headers yet i was thinking of. Ls6 cam ..with some 243s full bolt on
Old May 17, 2013 | 05:29 PM
chrisfrost's Avatar
If I were You I would seriously consider the pump I believe it's Schumaker racing has 4 $150 . The relief valve is a ball bearing instead of a piston so it really can't get stuck.
