Single belt harmonic balancer?
I doing a conversion to my tvr and using a L33 engine.
My first problem was the crank pulley and water pump was fouling the chassis cross brace.
So I have a Ls3 water pump on order which should clear no problem, but I need a low profile crank pulley to suit, I see that nearly all the one's I can find on the web are meant to run two belts, I only need the back one.
So my question is can and where can I buy a single belt crank pulley?
If not what is the lowest profile pulley I can get to run with my Ls3 water pump?
I've read that the corvette would be my best bet, but what year and model do I need?
Thanks
Alex
Thanks
Alex
