is going to synth oil safe after 73k miles?
is going to synth oil safe after 73k miles of normal 'dino' oil?
engine doesn't eat much oil right now, everything seems to be fine.
is it safe to go to synth, or should i just stick to tried and true and what the car is used to so far?
Synthetic is always better for performance and protection. Regardless of mileage, it can be used. Just don't use it if you are leaking or burning oil. Synthetic is "slipperier" so it can make a small leak turn into a large leak.
What's the best way to check for leaks that would affect my decision here?
