Another broken Yella Terra rocker arm
#61
You can go with a custom manton 11/32 pushrod also, and no need to worry about enlarging the holes in the heads for the bigger PRs. I have ran a few sets of them in cars, and it makes a difference. But there was also a thread on here about running a thicker wall 5/16 pr helps also. Someone needs to make a large comparo featuring all that info...
PS, when this happened to Scorpion a few times, people literally stopped buying them...no love for the American company selling American Made products...AND who hired quite a few of the tech guys/reps from Crane when they went out of business a while back. Oh yah and they offer a lifetime wnty on their rockers. No need to wait to contact them. My .02.
http://m.corvetteforum.com/157250702...ml?styleid=132
Increasing OD is what wins, not necessarily wall thickness..
#63
The Scammer Hammer
Scorpion has come leaps and bounds since their issue they had. They offer a lifetime warranty, and when I had mine, I spoke directly to the president of the company, not a sales rep.
That being said, they're coming out with a shaft system as well.
Guys, they ARE a great alternative to HS or YT's.
#64
#65
The Scammer Hammer
Nothing that I've heard yet. There's this option as well...
PRW # 3334611 PQX Series Aluminum Shaft Mount Rocker Arm System 1.7 Ratio for Gen III GM LS1/LS2/LS6 V8 Engines. The Performance Quotient® aluminum rocker arms are made from 6061-T6 or Series 7000 2024 aircraft quality aluminum alloy extrusions. Each rocker body is relieved for extra valve spring clearance and anodized for added strength. CNC machined billet steel pedestals, ground steel alloy rocker shafts, PRW SCM-4135 alloy steel fasteners, and needle roller bearings from the finest manufacturers in the world comprise the foundation of these rocker arm systems. These complete kits include all the components and hardware required for a professional installation. Benefits/Characteristics • Rated 750 lbs. open spring pressure • Internal oiling system for long-lasting performance • SAE 42100 full complement precision needle and cage roller bearings
Just tossing ideas out here guys. That's it. But you have to admit, a shaft system, guaranteed to 750# open spring pressure, with a warranty, coming in around 400 bucks, with all shims, hardware, and even 2 PR checkers is pretty hard to beat.
#66
Christian
#67
So HS rockers are junk also then?? Cause i just ran into a bent #1 exhaust valve & two lifters failed on #3 cylinder. & im wondering if i need to go with the full length shaft mounted rockers & a thicker pushrod to help...
#68
The Scammer Hammer
I'd imagine if it isn't *too* bad, a stiffer / thicker pushrod as well as a bit more seat/open pressure would help. They do look a bit robust though, I'll admit.
Just kicking the can and tossing ideas. It sucks seeing these threads pop up. I feel for you guys.
#69
I would not get caught up in all the extra propaganda. I am not fond of PRW stuff. I'd rather srick to Scorp myself. Everyone bitches about buying outside USA but its been a while since I have heard any A) talk from someone who actually bought scorpion B) has actually had a failure from them in a rather long time. Good guys and a good company.
