Cam MPG Question.
A 800rwhp twin screw car has the same 14.8-15.3 AFRs as stock...does it mean it's going to use the same amount of fuel? Nope because it has more air and thus more fuel.
A bigger duration/higher lift cam will allow more air in the cylinder each intake stroke, thus it will require more fuel to attain the same stoich AFR, so it will use more fuel.
How you use the power created by that is going to have a bigger impact on overall fuel efficiency, but all in all a cammed car will use more fuel per stroke than a stock cam car.
My car in 6th gear with stock gear turns 1500rpm at 65...that's fine if you guys like to cruise at that rpm I don't. On long trips i'd hold out 6th but normally i don't use it until 65-70mph.
Like they say: Mileage will vary...i also have a lead foot and prefer not to bog down the motor. It has zero pull at that rpm i like my power.
My car would regularly get 24-26mpg highway with bolt ons, and around 18 city. It took a hit, just about every car will take a hit with a cam swap...if you guys want to continue arguing that it's fine.
I feel you. My converter locks at 50 mph. With my gears, it drops to an insanely low rpms. Like 1200. Had to pull some timing out. Car wont accelerate with any power there. It still gets some kr if I lean into it.
I should be able to get better mpg out of the car i'll post up next road trip i do. It's rare i get a complete highway tank out of it. Also lots of elevation changes where i live.
Also thinking about swapping in 4.10s, might be too much.. i wish i had a 3.73s laying around. The 6th gear is so long in these trans. I hate the 5-6 shift they are so spread out.
