rod bearing question
Old May 30, 2013 | 06:42 PM
dartpro1's Avatar
Default rod bearing question
I Have Stock Rods And Crank With King Bearings Cr807hpnd. Does It Mater If The Bearing With The Hole Goes In Rod Or Cap?
Old May 30, 2013 | 10:13 PM
Justhereforinfo's Avatar
Stock rod bearings don't have holes. Are you sure those are the right bearings?
Old May 30, 2013 | 10:45 PM
dartpro1's Avatar
I'm Using King Bearings.
Old May 31, 2013 | 04:39 PM
chrisfrost's Avatar
I've got a set of standard size stock aluminum/silicon King Bearings and They have no hole. The mains have a hole and it's very easy to see where the shells with holes go ,,,,,They line up with holes in the block sides of the mains caps
Old May 31, 2013 | 04:49 PM
dartpro1's Avatar
These Are Rod Bearings. I Called King. Thanks
Old May 31, 2013 | 08:49 PM
KCS's Avatar
KCS
Moderator
You have bearings for an aluminum rod that has a dowel. Just look at the back of the bearing for a L or a U (lower or upper).
