LS1 383 Stroker build. heads and cam
Old May 31, 2013 | 07:00 PM
rayman3550's Avatar
Default LS1 383 Stroker build. heads and cam
Initially i was going to stick with the stock bottom end, but after some thought i decided to hell with it and bought a stroker kit for some extra power. So now all my research on heads and cams have went down the drain because i have a bigger cubic inch block now. The motor is still in the machine shop, so I am trying to get heads and cam before it gets back. Any input or related setups would be great!
Somebody recommended me a cam yesterday at a speed shop of this grind:
232/236 .580/.580 on a 114.....When i saw this i thought it was very small for a 383 or even a 346. Has anyone ran this setup or something close? He said with stock heads i would be 400+ and with a new set of good heads i would be 450ish. To me that doesnt seem right. Before talking to him I was thinking something more like an ms4 or a custom grind with a .6xx lift.
Old May 31, 2013 | 07:42 PM
deerslayinrednek's Avatar
Talk to Martin@Tick Performance about a cam
Old May 31, 2013 | 07:44 PM
rayman3550's Avatar
Yah i havent had a chance to i work until 530 every day and he is not in at that time.
Basically what i need to know here is if that cam is too small? He said he recommends that cam to everyone running a 383 stroker ls1 for daily driving and some track purposes.
Old May 31, 2013 | 08:16 PM
JustAFooL's Avatar
Whats your goals with car? DD? Track car? That cam is a decent sized can in my book for a 346, I would think maybe a little small for a 383 though. You should talk with a shop though. Any reputable one will put you on the right path.
Old May 31, 2013 | 09:29 PM
cookba's Avatar
https://ls1tech.com/forums/dynamomet...-included.html
Old May 31, 2013 | 10:01 PM
badassracing's Avatar
I ran a 383 with afr 205s and a 236/238 112 cam and it ran 11.08 in a full weight camaro with a m6. I never had it on a dyno but the heads and cam eventually were sold and put on a 6.0 and dyno'd 475 rwhp.
Old Jun 1, 2013 | 05:51 AM
RezinTexas's Avatar
I think the $25 to Patrick G for a cam spec is money well spent. He takes dozens of variables into consideration to spec a cam for your needs and wants.
Old Jun 1, 2013 | 08:09 AM
BOB FERGUSON's Avatar
Default Cams ??
Hello,
Bob here, looking for the right cam for a daily driver build we are doing.
Who is Patrick G. If you could send an e-mail address or better yet a phone # we would appreciate it.
Good buildin'
Old Jun 1, 2013 | 10:07 AM
JustAFooL's Avatar
Originally Posted by BOB FERGUSON
Hello,
Good buildin'
Just search Patrick G in the search button, his name is al around this place.
Old Jun 1, 2013 | 11:58 AM
RezinTexas's Avatar
http://www.guerragroup.com/#!camshaft-help/c1mq5
