best oil for the LS1 engine?
and now my engine sounds like a bag of marbles for the first 45 min
till it quiets down
I heard to use a PF59 filter as it has more flow too
Engine is just noisy
Help!
2000 Z 28 WITH 90K ON IT
I feel changing your oil is more important that what you use. I run RP HPS only because I do...Nothing wrong with many of the known off the shelf brands. Just don't run it for 10,000 miles! If you drive your LS like I know most people do...Should be changing it at 3000 miles.
What oil were you using prior to Mobil1?
I may get some ...
I have been a synthetic oil fan for years..Mobil, Amsoil etc...however, I am returning back to dino after i noticed a reduction in valve train noise when on a trip i made an oil change to dino as a temporary oil change....I have done some research and it is obvious that modern oil is good stuff and the key is to change it often....I am certain i can change the oil every 3,000 miles and the filter every other change and come out ahead of that 12.99 a quart oil.and still maintain adequate lubricants in the crankcase.....I have oil coolers on both bikes and i do not dog the bikes....
----->Read this.....I had to get rid of the Harley Syth oil out of my Sporty, made it sound like a chatter box.
Switched to Rev Tech's 25-60. Quiet as a mouse.
Never going back to syth
I run rotella T6 5w40. I feel confident running that oil. I drive my car kinda hard so i change it every 2000 miles. racing it about each weekend and driving about every day.
car is also an heads cam car.
Don't declare anything as being the "Best" until you have proof. 5W30 in Syn is too much like water and doesn't do much for cushion in the hotter months. I use the 15K M1 Oil in 10W40 during the fall/spring months and 20W50 during the summer months. I only use 10W30 when it gets colder than 30 degrees F. I change oil every 10K or so and my 5.3 doesn't leek a drop nor does it use any either. But then, I'm not pushing all the power most of you are, I am towing quite often and using my truck for off road use A LOT!
To each his/her own I guess.
The zinc is suppose to give the oil a great anti-shearing ability. It's been reduced over the years because of the EPA and the fact it kills cats. Only black ones though.
What kills me, is why would my truck require 5W-20? Do they expect it only to run in 70 degree weather?
