Forged internals
Old Jun 4, 2013 | 11:10 PM
82budgetdrop's Avatar
Default Forged internals
Building a 5.3 from a 2001 suburban for my c-10 and getting ready to send the block to the machine shop. Does anyone make a forged bottom end for the 5.3? I know the factory components are strong in these motors but going for some big numbers and want to cover all my bases.
Old Jun 5, 2013 | 08:15 AM
redtan's Avatar
Rods are the regular 6.125 for a 3.622 stroke and Wiseco makes some 3.8 or 3.82 pistons I believe which is a slight overbore.
Old Jun 5, 2013 | 10:44 AM
ckpitt55's Avatar
why not go after more displacement? 3.905 pistons cost the same as 3.8-.82 pistons. pretty much a "free" upgrade as you'll be paying to have the bores sized any way you cut it.
not sure if you're going N/A or not, but if you are the increased displacement would also be a "free" bump in static compression which is definitely desirable. Combine that with some 0.040's for tight quench and you'll have an explosive setup (literally, but in a good way).
