Ticking under acceleration
Old Jun 6, 2013 | 10:07 PM
AmnSF's Avatar
Default Ticking under acceleration
My car will idle without any problems but anything above 25% throttle, a ticking noise is produced and gets quicker as the rpms increase. It's coming from the driver side. I have my guess but would like to see if anyone can confirm it.
Old Jun 6, 2013 | 10:40 PM
bat1's Avatar
This is what I been told to check..............
Loose spark plugs, a bad pulley bearing, vacuum leaks, exhaust leaks. get a screw driver and listen for engine noise like a bad lifter or loose rocker arm..could be piston slap too..
I had a ticking noise and it was the A/C belt one side of it was gone! (strange) also check the PCV valve and the hose for leaks..
hope this helps...
Old Jun 7, 2013 | 12:33 AM
2002 blue z28's Avatar
Header gasket maybe.
