is my up block ok?
Old Jun 7, 2013 | 08:04 PM
treavblom's Avatar
Default is my up block ok?
ok so I am new to the forum but I have been reading up a lot. I just got an lq4 motor and I was getting ready to order some l92 heads for it so I started getting the motor ready for it. I got the stock 317 heads off and was cleaning the pistons when I noticed odd colors on the cylinder wall. to me it just looks like a hot spot? maybe a crack?(hopefully not!) here is the pictures. its in 2 different cylinders on the left bank. I have not taken the right head off yet. thanks for the help!
Attached Thumbnails is my up block ok?-img_20130607_143526_527-451x800-.jpg   is my up block ok?-img_20130607_143448_487-451x800-.jpg
Old Jun 7, 2013 | 11:32 PM
mjcotroneo's Avatar
Hmmm. Can you feel any separation in the metal? Anytime I build an engine I would take the time to tear it down and hone it. I've seen a lot of blocks with pitting from rust but no marks like that.
Old Jun 8, 2013 | 06:01 AM
RockinWs6's Avatar
Wow I'd be dye checking that for sure, looks like a crack.
Old Jun 9, 2013 | 11:52 AM
EricYJ-TA's Avatar
Yep, looks like a crack. Take it to your local machine shop and see what they can do about it.
Old Jun 9, 2013 | 12:43 PM
99 2500's Avatar
When I pulled the heads on my 6.0l to change cam and lifters, the cylinder bore had similar weird looking color marks on them but the surface was still smooth. It now has 7000 miles since with no problems.
Old Jun 12, 2013 | 11:25 PM
treavblom's Avatar
well heres an update I took it down to the machine shop and the owner is a friend of mine and he said they are cracks and he is sleeving both cylinders for $325
